Root Root and CWM Recovery for ZTE Concord 2
Ya Hroark and his method have nothing to do with Mega either. His PC method is however at the beginning of this thread but has NOTHING to do with mega.
I take that back on second look I see that there might be something within mega an updated method maybe I'm not sure as to I can't link to mega myself
Not the one under the mega linked one. To be honest this is the first time I seen a mega linked methods. I myself didn't use a PC anyway so I wouldn't be of any help with the PC method
Could you get ahold of Hroark13 for me then?
Bro, its not like I got it like that with Hroark to just go hunting him down on the forums here to ask him why mega doesn't link us all to its file/files. Not to mention that would be more of a request for Mega to update theyre linking issues. Which I do plan on rating Mega and maybe emailing them cause I use mega aswell. But as far as hunting Hroark13 down I'm afraid I will leave that up to you. You're chances are as good as mine bro. Sorry man wish I could be of more assistance.
Hello, @hroark13, I was wondering if you could send me the rooting file for the Z730(Concord II). The MEGA file that you put in the thread is...well...not working. I would really appreciate you sending this to me, as I crave to root this thing. (Without Kingo.)
Also, regardless of HOW you Root, you can always install CWM recovery and flash a ROM that doesn't have or use Kingo cuz I made them with SuperSu instead. SuperSu will completely replace Kingo and you'll only be able to remove bloat by installing the Deodexed/Debloated ROMs. The J011y Xper!ment is further modified to look nicer/be faster.. Your system is write protected, don't forget.. So I made the ROMs for options. Go ahead and Root with Kingo and replace it with a better recovery then ROM that doesn't use Kingo.
Yup! as soon as you gain root with kingo you can run SuperSU right over Kingo. Then just uninstall anything left on you're device labeled/affiliated with Kingo, which would be Kingo rooting tool and Kingo user apk off playstore. And yes bcrichsters Jolly Xper!ment also includes SuperSU.
So, I used the old file and (pooossibly) successfully rooted. But now my phone is acting up just a little, not neccesarily a softbrick tho... Edit: @bcrichster, this is off topic, but could you make Jo11y Exper!meant running lollipop or marshmallow?
No Sir I can't. That device is stuck with JB 4.3 but I did in fact include some KK APK's for ya. I'm a bit of a Themer, not a compiling Dev. Yet.
My phones going all stupid now and freezing at random
Your next function should be to immediately install CWM recovery (before any reboots) then install another ROM with permanent Root, that should straighten you out..
I would have, accept I can not give permissions, and my phone even running SLOW now, now would really be a good time for teamviewer...@bcrichster
That.. Doesn't make sense. Either you have Root or you don't.
1. Do you have the desired ROM you want installed on external SD?
2. What do you mean about not giving permissions? You don't need to worry about accessing permissions if you're in recovery.. Make sure you can access recovery as well
I've never done TeamViewer with ppl before and trust maybe 3 Lol with PC's and ur not currently one of them. Sorry, Lol. [emoji12]
