malickmalick
thx i just got back from work and will try doing now
Jolly Xper!ment ROMwhich rom do u recommend the most. i just finished flashing the cwm and i wanna know which
thx could u give a description on how to install correctlyJolly Xper!ment ROM
yes sirIs this going to be the first ROM you've ran?
im in backup and restore what would i choose now?You need to boot into recovery & go into backup & make a full nandroid backup is first thing.
I dont get what you mean here. do you mean to Wipe data/factory resetwipe complete ROM everything but youre SD card.
Always try to backup to external SD or you'll suddenly find yourself outta space real quickly. [emoji41].theres
-Backup to /sdcard
-backup to /external_sd
-free unused backup data
yea thats what happened but there wasnt an error saying sd card wont mount so it couldnt even look at the external sd cardAlways try to backup to external SD or you'll suddenly find yourself outta space real quickly. [emoji41].
Glad you got it sorted.. What was the deal?nevermind i fixed the problem
OK.. It was bucking the themed play store?! Huh.. OK! Ty- for the heads up and report.So the Roms custom Google Play Store wouldn't let me download certain apps saying my device was not compatible with the app when I knew it was and also said for some apps some type of network error the error is:
Error retrieving information from server [RPC S-7 AEC-7] [RPC S-5 AEC-0] <-the last number right there is a zero
This is how I fixed it
1. I downloaded the latest version of google play (which replaced the custom one)
2. I went into the phones settings and went to the accounts tab then logged out of my google accounts that were connected to my phone
3. I logged back in with the accounts
4. I went into the settings>apps and swiped to the All tab
5.I went down the list and cleared the data from Google Play Services, Google Play Store, and Google Services Framework
Then all I did was go back into the Google play store and Boom the apps that weren't working before started working just fine.![]()
so this is your Rom right?OK.. It was bucking the themed play store?! Huh.. OK! Ty- for the heads up and report.
. Ive looked through so many things and so many people dieng to get this phone rooted! and failed videos that dont work for people.
