root and hdmi out
dirtmouth
I can find no logo for hdmi anywhere . anyone know why? I cant view anything on my tv, however this is the first time I have tried. this may have been a waste of 25 dollars....
Are you asking where the hdmi plug is on the phone? Beside the USB mini plug. You will need a HDMI micro to standard cable. What do you mean by a waste of $25.
I cannnot or dont know how to view on the tv via the hdmi out on the DX.
Someone said go to gallery app , open a photo then click on the hdmi logo....well I cant find that logo anywhere
Is your X hooked to the TV? If so and you go to Gallery and do not see the HDMI "logo" then the ROM you are running probably doesn't support it. Can you flash back to stock to see if your HDMI is working?
That must be it!...25 dollars for the cable, is it really that usefull at this point.
are you using a custom rom? if so what rom are you using?
when i had liberty 1.0 installed hdmi was not supported. i am now running apex 1.4 and apparently it is supported, although i have not actually tested it out yet.
but a rom could be the culprit.
ya running apex 1.4 and no hdmi logo in gallery
Were you actually able to get hdmi out working poperly? I finally had reason to try it out the other night and i cant get pictures to or video to work from the galley, yet audio plays through. I also cannot get real hdmi working.
Apex 1.4.1 w/blur gallery. And real hdmi.
yes i can view on my flat screen 2 years old the pics. havent tried music or any type audio or video yet .
Hello to all,... I just got my Droid X flashed to Liberty 1.5. Do I understand you right ... there is no way to use the HDMI out with Liberty 1.5?
If that is so (and I'm not doubting you) why would anyone run Liberty if Apex 1.4 is just as good plus you get to use your HDMI? Thanks for your feedback...
