Root Root droid w/ broken power/lock button?
jddogg
So i've been dealing with the whole broken lock/power button issue for a while with my droid.
Now i've been looking into rooting it and was looking into the directions on how to do it when i realized you need to use the lock/power button in the whole rooting process.
Is there any way around this? Or will it be impossible to root my phone without being able to access the power/lock button?
why dont you just take your droid into verizon and exchange it?
My guess (only a guess) is you can do a battery pull to reboot your phone after everything is backed up and flashed. The power button is used to go back to a previous menu in the recovery but you might just have to reboot between operations. There is a great program called Quick Boot which will allow you to easily boot into recovery (or just reboot your phone) without using the power key. It does run from the operating system, not from the recovery menu.
question is, how odo you turn your phone on without a working power button in the first place? exchange it first, then root it.
The phone automatically boots when you plug it into a power source. I have to agree though, take it in and exchange it.
my Droid is rooted for sometime now. I have broken power button just this morning. If I go to Verizon what would they might say about it when they see phone is rooted? Also, is this repair still under warranty or not? i got the Droid end of last year.
Use either dm updater or an sbf file to return to stock then take it back.
MFG warranty should be a year.
In sprecovery the del button serves the same puprose as the power button to back out. (Hard keyboard). Also the directon pad will navigate up/down and center of dpad to select.
