Root Root help please!
fyrebahl
Running rooted DX with 2.2. When the OTA update for 2.2.1 came out the update worked fine but I seem to have lost root permission. I used Silent Killers "Root my X" method to obtain root and I've tried to use the unroot option to no avail.
Can someone tell me how to get root back so my DX can once again be awesome?
Thanks
So when you type su into terminal emulator you don't get root access? Try z4root its not on the market but a quick search here or on Google will get it for you. Worked like a charm for me.
fyi, z4root is no longer on the market.. which imo is dumb!
did z4 reboot your phone for you? If so, you're rooted. Make you're disconnected from your 'puter.
now z4 has a dialogue box that says "your device has an su binary and the force unroot option has been activated for you" and there its an unroot option, so my phone its rooted once again so why do my root apps still fail? Specifically jrummys dx overclock, root explorer
Thanks
Try uninstalling the root apps and reinstalling them again.
When I re-rooted my overclock app wasn't working for me either. But I deleted it and re installed it. It worked fine afterwards.
as was said before, open terminal emulator.
type "su" (without the quotes). ..... does it show a # or a $? if you get a # it is rooted. if you get a $ it is not. try running z4root again, and make sure it restarts the phone.
if you are rooted (#), uninstall the apps, and reinstall them.
