Factory resetting through TWRP won't remove root if the rom you flashed includes root (which most do).
It will return your rom to the state of a fresh flash. Sort of like when you factory reset on a stock device. You will lose your data and settings and user apps, and it will be like you just flashed the rom for the first time.
