Okay, I've done this twice now and each time it says:
What's that mean?
I can use J Pal's terminal emulator, get su status, and CD to /system, but there's no xbin directory in /system. And I tried "mkdir xbin" but file system is read only in terminal emulator.
Maybe the script should use "bin" instead of "xbin"? Just wondering as I do have a "bin" directory.
Uninstalling shows:
And I'm worried about the "Installing stock VD recovery...: No space left on device" error.
Code:
Installing persistent root... install-root.sh: cannot create /system/xbin/busybo
x: directory nonexistent
Unable to chmod /system/xbin/busybox: No such file or directory
Done
What's that mean?
Uninstalling shows:
Code:
Getting ready to
UNINSTALL persistent root (UNROOT)
Please verify ALL of the following:
SD card is INSERTED
USB Debugging is ENABLED
USB Storage Mode is DISABLED
LG USB/Android drivers are INSTALLED
Phone is connected to USB port and recognized
Press any key to continue . . .
Waiting for device to be connected [press CTRL-C to cancel]... Found device
Proceeding with install
Asking for root permissions...
Please turn ON phone and EXIT the lock screen
AFTER you press any key to continue, if you are PROPERLY ROOTED, you
MAY see a PROMPT asking for permissions. Please ALLOW root access.
---- BEGIN LOG ----
...Proceeding to copy necessary files...
push: copy2sd/000root/xionia_cwma_12518.6.img -> /sdcard/000root/xionia_cwma_125
18.6.img
push: copy2sd/000root/Superuser.apk -> /sdcard/000root/Superuser.apk
push: copy2sd/000root/su -> /sdcard/000root/su
push: copy2sd/000root/recovery_vd.img -> /sdcard/000root/recovery_vd.img
push: copy2sd/000root/install-xionia.sh -> /sdcard/000root/install-xionia.sh
push: copy2sd/000root/install-vd.sh -> /sdcard/000root/install-vd.sh
push: copy2sd/000root/install-unroot.sh -> /sdcard/000root/install-unroot.sh
push: copy2sd/000root/install-root.sh -> /sdcard/000root/install-root.sh
push: copy2sd/000root/install-cleanup.sh -> /sdcard/000root/install-cleanup.sh
push: copy2sd/000root/flash_image -> /sdcard/000root/flash_image
push: copy2sd/000root/busybox -> /sdcard/000root/busybox
11 files pushed. 0 files skipped.
1883 KB/s (12815963 bytes in 6.645s)
Installing stock VD recovery... error writing recovery: No space left on device
Done
Uninstalling persistent root... Done
Waiting for filesystem to sync... Done
---- END LOG ----
Check for any errors. Assuming there are none, the UNROOT was successful.
Getting ready to reboot...
So I posted my findings. Have a happy rooting.
