Okay, I've done this twice now and each time it says:
What's that mean?Code:Installing persistent root... install-root.sh: cannot create /system/xbin/busybo x: directory nonexistent Unable to chmod /system/xbin/busybox: No such file or directory Unable to chmod /system/xbin/busybox: No such file or directory Done
I can use J Pal's terminal emulator, get su status, and CD to /system, but there's no xbin directory in /system. And I tried "mkdir xbin" but file system is read only in terminal emulator.
Maybe the script should use "bin" instead of "xbin"? Just wondering as I do have a "bin" directory.
Uninstalling shows:
And I'm worried about the "Installing stock VD recovery...: No space left on device" error.Code:Getting ready to UNINSTALL persistent root (UNROOT) Please verify ALL of the following: SD card is INSERTED USB Debugging is ENABLED USB Storage Mode is DISABLED LG USB/Android drivers are INSTALLED Phone is connected to USB port and recognized Press any key to continue . . . ---- Waiting for device to be connected [press CTRL-C to cancel]... Found device Proceeding with install ---- Asking for root permissions... Please turn ON phone and EXIT the lock screen AFTER you press any key to continue, if you are PROPERLY ROOTED, you MAY see a PROMPT asking for permissions. Please ALLOW root access. Press any key to continue . . . ---- BEGIN LOG ---- ...Proceeding to copy necessary files... push: copy2sd/000root/xionia_cwma_12518.6.img -> /sdcard/000root/xionia_cwma_125 18.6.img push: copy2sd/000root/Superuser.apk -> /sdcard/000root/Superuser.apk push: copy2sd/000root/su -> /sdcard/000root/su push: copy2sd/000root/recovery_vd.img -> /sdcard/000root/recovery_vd.img push: copy2sd/000root/install-xionia.sh -> /sdcard/000root/install-xionia.sh push: copy2sd/000root/install-vd.sh -> /sdcard/000root/install-vd.sh push: copy2sd/000root/install-unroot.sh -> /sdcard/000root/install-unroot.sh push: copy2sd/000root/install-root.sh -> /sdcard/000root/install-root.sh push: copy2sd/000root/install-cleanup.sh -> /sdcard/000root/install-cleanup.sh push: copy2sd/000root/flash_image -> /sdcard/000root/flash_image push: copy2sd/000root/busybox -> /sdcard/000root/busybox 11 files pushed. 0 files skipped. 1883 KB/s (12815963 bytes in 6.645s) ---- Installing stock VD recovery... error writing recovery: No space left on device Done Uninstalling persistent root... Done Waiting for filesystem to sync... Done ---- END LOG ---- Check for any errors. Assuming there are none, the UNROOT was successful. ---- Getting ready to reboot... Press any key to continue . . .
I gotta say i like the new root and the ROM u supplied mikekelso421...awesome work
however i did still seem to have issues with my market FC on its own. I found a gapps install and did that. Now when i go to create an acct it reboots. Is there a specific gapps that i need install that work with ur ROM or will any do???
sammyz has been helping on another thread i have specifically with this issue, but i thought i would throw it u and see what u think
Hello,
I followed all the steps(downloaded and installed lg drivers, enabled debugging, phone screen unlocked, sd card mounted, etc), I ran the "RUNFIRST.bat", pressed "A" and did all the process, phone rebooted and I couldn't find the SU app, it didn't install. Did the same process like 5 times and still it doesn't get rooted![]()
Could anyone please help?
What operating system are you running? xD just by the username it sounds like your not running windows haha
FIXED!!! I had to format my sd card though.
Hey Mike & board members!
I recently downloaded the root kit to root my LG optimus M for metro pcs.
Everything seemed fine and i ran the superuser.apk to root. Afterwards it said my binary was outdated, and asked me to automatically look for one but it failed and told me to enter recovery mode and flash my own binary..
So I entered recovery mode via the vol Down, menu, and power button.
But this is where its strange now. Im no phone expert, but it doesnt seem like im in recovery mode. It seems like it did a factory reset? Ive lost all my apps and widgets, and it even asked me for my time zone and time/date info again.
And now I do not know if i AM in recovery mode or if i somehow did a reset. If i am in recovery mode can you PLEASE tell me how to go back to normal mode? And if this IS looking like my fone reset, then why and how? I do not even want to download your DEBLOATER rom because at this point i have no idea what is going on..
Any help from anyone is very appreciated, thank you.
Thx Sammy & vulcan..
But I'm not sure why u say I'm not rooted.. after I first install the superuser.apk it showed on my phone.. but just when I ran it it failed n told me my binary outdated.
Why would vol down+home+power reset me? And here's the thing..although no stuff is showing on my fone.. my sd card shows only 880 mb free and the rest 29 gb is taken.
Guys pleeeease help however u knoe.. this fone is the fone of my girls friend. If I really reset her ima hv to leave town now LOL
after I first install the superuser.apk.......
Go to market and update superuser, then update binaries........never wipe sd card!(unless you back it up to your computer first) always wipe sd-ext when changing ROMs as well as /data /boot /cache /dalvik-cache (which you should not do right now because it sounds like you want to stay on stock since you're trying to keep everything....flashing a custom ROM would make you lose everything again...unless you use titanium backup)Ok so firstly thanks for the replies and ur time Sammy & vulcan.
Basically right now.. the rooting and binary issues are my 2nd priority. Right now I NEED to try to get the stuff back on the fone.
I DID follow the instructions..on the first post on first page. I DLed the root kit and then wentin to install the superuser.apk. then after..the superuser showed on fone and I tried to run it and it told me binary issue. It told me to enter recover mode to flash my own binary. So I checked Mikes post again forinstruction on how to do recovery mode..followed it..and I'm here where I'm at now.
I need to find out how to exit this mode.. where my fine showin no stuff(pics, ctcs, apps etc) but on the sd card it hasn't veen wiped its still got the data on it..just not showin.
I didn't click format sd card because I've been told it wipes the sd card? Right now I'm tryin to atleast get my old fone mode back (rooted or not)
Thx again for replies
