Hi All,
See if anyone has any advice for Rooting my Lucid 2. I've been getting the errors listed below, appears the file system is well locked up. And this is what i've done to attempt to correct it.... Got the MetroPCS drivers for the 870. I've went and followed the Unbrick/Unroot Lucid 2 walkthru and flashed the KDZ. And didn't even get stuck in a loop. But one thing that was different then any instructions I've seen, to factory reset the phone I was to hold down the down volume key and power on the device. This actually put my phone into safemode, never prompted to reset the device. But I did go and factory reset my phone under the menu anyway... but still getting the same result. FYI I did try to apply the root patch while in safe mode and got the same errors.
Thanks in advance for your support,
-M
[*] Press enter to root your phone...
Press any key to continue . . .
[*] Waiting for device...
* daemon not running. starting it now *
* daemon started successfully *
[*] Device found.
[*] Rebooting device...
[*] Waiting for phone to reboot.
[*] Nerfing RCT...
3742 KB/s (657700 bytes in 0.171s)
usage: kill [-s signame | -signum | -signame] { job | pid | pgrp } ...
kill -l [exit_status ...]
[*] Enabling persistent root...
failed to copy 'su' to '/system/bin/su': Read-only file system
Unable to chmod /system/bin/su: No such file or directory
link failed Read-only file system
failed to copy 'Superuser.apk' to '/system/app/Superuser.apk': Read-only file sy
stem
Unable to chmod /system/app/Superuser.apk: No such file or directory
[*] Installing BusyBox...
failed to copy 'busybox' to '/system/xbin/busybox': Read-only file system
14 KB/s (15228 bytes in 1.000s)
Unable to chmod /system/xbin/busybox: No such file or directory
-M
[*] Device found.
[*] Nerfing RCT...
stem
