Root Rooted 2.1
X10iUser
Android Expert
Download the SuperOneClick.
Copy these three files from the Android SDK tools folder...
adb
AdbWinApi.dll
AdbWinUsbApi.dll
(which are zipped here - tools.zip)
...replace the ones in the SOCR folder.
Run it, but when/if it starts looping do this...
untick/retick USB debug while it's running
...and you should see...
Running rageagainstthecage...
ROOTED
Getting mount path...
/dev/block/mtdblock2
OK
Remounting system with read-write access...
OK
Pushing su...
1424 KB/s (26264 bytes in 0.018s)
OK
Pushing superuser.apk...
820 KB/s (196521 bytes in 0.234s)
OK
chmod su...
OK
Remounting system with read-only access...
OK
...install Titanium and BusyBox to confirm!
If you continue to get looping issues, install the PDANet Client on the PC and allow it to install the drivers for your phone and try again.
Some have said you don't need to replace the files, and that it can take up to 10 minutes. It looped for me but after doing the above, especially unticking/reticking debug mode whilst running it, and today installing the PDANet client it was almost instant.
I am still running 1.6, but will be upgrading when generic uk firmware is released. My phone is rooted now, but would it be wise to de-root it before upgrading?
Ah good, i'd thought as much but what with the apparent troubles people had rooting 2.1 today I didn't want to brick the phone :P
Cheers :)
Mine goes no further than Installing superuser.apk... :confused:
EDIT: Nevermind, I unplugged USB then went into settings->applications and realised that I didn't have the box ticked allowing none market apps, ticked it, plugged USB back in and it worked :)
EDIT 2: Although it said it had successfully rooted, and superuser is installed, no rooted apps will work :confused:
EDIT 3: Working now after installing Busybox :)
where can i find these file mate? where is that folder?
adb
AdbWinApi.dll
AdbWinUsbApi.dll
thanks...
...opps, okay so i need to download the SDK file.... replaced the files on SOCR folder, ran it, tick/untick the USB debug, but i am still stucked on the loop ratc....
pls help...
Hi.
You need to download the SDK (see link), or attachment...
Thanks mate, i did that, the whole 23MB file, but i will try your attachments and copy paste and see if it works...:D
... nope. still the same mate...
when i untick/tick the USB, i have three options
Connect your phone (update phone and manage account)
Install PC Companion
Charge the phone
so i always select Charge the phone.. but still nothing....i also installed the PDANet already.
how hard can it be?
What is the SOCR folder please? Can't find it....
Found it - didn't read properly and missed superonelink at the top.
This was a pain for me, but what you should do is connect the phone, get to your USB debugging screen on the phone (under Apps/development), toggle it on.
Do not close that page on your phone.
Then just open up the superuser program, click root.
My phone just went crazy at this point (connecting, disconnecting, PC companion pops up). Exit PC companion, click on the connect to computer, then toggle USB off and back on.
I tried this about 10 times with no luck and then once I toggled USB off/on in the span of 5 seconds, I was rooted. I am having some hang up issue with titanium. It is removing apps, but it's getting stuck - so I have to use an app killer to kill it, then re-open and go to the next app to delete.
Worked a treat, i copied files as per instructions.
the superoneclick never actually said complete, just seemed to hang on the installing superuser.apk, but looked and it was on. the rest was simple, Now rooted and all SE apps removed.
cheers
is it easier to do than it sounds? i dont wanna start playing with it and brick the phone. lol. is there a tutorial video i can folow to make it a little easier?
Just download z4root from Android Market and with one click you are rooted and it also has the option to unroot too.
i need to read up to see what i can get rid of. with my luck ill delete everything and have to start again, lol
Let's do it the REAL easy way... download z4root from the market... and it's done... Worked perfect and now i have titanium installed and working. No more playing with debug setting
