Fishwalker
Hi,
Android Version: 2.3
Network: Orange unbranded
Taskiller Used?: ES Armstrong's
[Optional]Are You rooted & which Rom: Rooted using Ginger Villain
OS: Mac OS 10.6 on Macbook Pro
Issue:
Rooted Desire running Ginger Vilain in a right mess after SD card partitioning and trying to restore app's+ data using MyBackupPro root- Please help?
Ok so I spent all day trying to understand jargon and have read sooooo many posts about each part of this journey that I have figured am going insane and just want one on one help with my issue so hoping someone can help me?
Have been running GV for a week and was fine except wasn't getting different colored LED's anymore like Froyo pre root and bluetooth was a bit dicky + main thing that is internal memory down to 8mb again from starting at 48mb when first flashed ROM so app2sd couldn't be working properly. NB. Had tried to partition with ROM Manager and had part of 512mb showing up in Quick system info under AP2SD, but it never seemed to work, e.g. storage never got used and internal cont. to go down, basically with GV ROM, it only let me move more app's across to sd card.
As had day off I wanted to do the partition properly using Gparted, as had read that was best for a clean partition. So have spent literally all Saturday trying to understand how to get Gparted running as it kept crashing on install. Finally got to the interface and partitioned as follows my 16GB SD class 6 card:1GB Ext 4 primary, 32mb Linux swap, rest FAT 32 primary so like 14GB.
It seemed to go well on test 4GB Sd card that worked in phone, so did 16GB and inserted in phone and booted.
All good I thought, phone booted fine and I was just going to go chill downstairs and set stuff up when I didn't have an app I wanted so thought i'd restore my backup's quick using Mybackup pro root.
I'd done a backup with both mybackup pro rooted and titanium free. As MBUP did batch restore, I went for that first and it seemed fine saying reboot before doing anything so I did that.
It was then that I got the dreaded boot loop or ginger villain screen and nothing I did e.g. pressing power would get me out so I had to take battery out to escape.
Tried booting into recovery (pressing power and down volume) and yet didn't really know what I was doing as a noob. From menu's tried looking for ROM to reflash but wasn't showing and had ben using ROM manager for that prev anyway so didn't know if was possible using recovery mode.
So tried clearing cache, wiping dalvik but that didn't work. Then tried clear memory from white screen and got phone to BOOT YAY!, albeit with all my settings and launcher pro gone. i.e Had to put in gmail account and language etc.
So next I think, right i'll just buy Titanium pro as my backup has screwed my system so went to market and paid. Downloaded pro key but as soon as it tried to install, the menacing ginger villain screen came back up flashing and then it went to the unlock screen. Titanium pro unlock won't install no matter what and out of 15mins refund.
Can't download any market app's so don't know what to do there? Help?
Aside from that which I need answering, does anyone think 'myback up' has done something weird, like added some 'pre ginger villain' 'Froyo 2.2 stock' type stuff or is it the partitioning I did? Neither SD card worked until I cleared internal memory.
Please help? My Saturday is destroyed!
Issue:
