shadowseph
Just fyi I've checked almost every single bootloop help thread before posting this so here goes:
I have a rooted Droid X on .595. I wanted to upgrade to .596 and when I hit the app "Droid X bootstrap" to reboot into recovery all it did was send me into a bootloop. I researched all solutions and even attempted to do a factory wipe (holding power + home then search after andy & exclamation sign shows up) because I was told Droid X bootstrap can get you there.
Then I tried to flash my Droid X but all the attempts have failed. Using 4.8 (then 4.9 afterwareds) RSD Lite, I had tried to use numerous .sbf files (from .340 to .596) to try and flash but the error remains the same: "flash failed" or "fail". Everything looks solid beforehand (Win 7 OS) and RSD detects the usb connected DX but that's as far as I can get.
Just so more info, I have used "Gingerbreak" app to root the phone and downloaded clockwork recovery as a backup recovery just in case Droid X bootstrap doesn't work but I didn't use clockwork at the time.
I even tried to let the bootloop continue for about 15 minutes to see if there was an end to this horror but still no go. I'm really out of options except going to Verizon and attempting for them to replace my phone (which I highly doubt) but I was wondering if anyone has any advice to this matter I would humbly appreciate you with gratitude.
Thank you.
(Edit: Just more info on the situation I used bootloader 30.04 when flashing an .sbf)
UPDATE: I have found a way to do a factory reset and now wiping. Will update if there is any complications.
UPDATE 2: After a few battery pulls, still no results getting the OS to boot up. Unfortunately, my situation still remains the same
Thank you.
