Hey guys,
I am new here as you can tell by this being my first post. I have a Droid X that I rooted successfully last night using z4root.
I did make a bootstrap nandroid backup, and I have installed Titanium Backup and registered it.
The System Version is 2.3.340.MB810
Android Version 2.21
There are just a few minor problems I have noticed since rooting and I was hoping someone here may be able to help me.
1. I cannot seem to get Amazon MP3 to uninstall.
- I use Titanium to both uninstall and do a force stop and reboot. When it restarts the program is still there. Other bloatwear I removed with no problem.
2. Some apps like RockPlayer will not install successfully. (I had to uninstall it and it will install now but not open. I have tried the Rockplayer Universal and ARMv6) Same results with both - crashed when I try to open it. Also - what is the difference in the ARM versions?
3. I noticed that when I am in the app market, I will click on something and it will simply say "loading" and hang, I hit the back button, go in again and it may go. I never had this issue before.
Any ideas or suggestions would be helpful.
*EDIT* I just noticed that Skype Mobile keeps coming back too.
Thanks
Thanks
