Root rooted or waiting?
whatcha gonna do?
  • ROOT!
    Votes: 50 63.3%
  • wait for bootloader.
    Votes: 25 31.6%
  • i have an iphone.
    Votes: 2 2.5%
  • wat?
    Votes: 2 2.5%
  • Total voters
    79
I decided to root for 2 reasons. 1., being the apps I missed that require it and 2., Because when a bootloader is released I have a feeling Rom Manager won't be to far behind with easy backups/rom loading and since I'm already rooted I can just download it from the market again and go! :D
I plan on waiting for a week or so to see if any difficulties arise and what the work around involves. However, if s genius programmer manges to crack the boot-loader before that (unlikely) then I'll root early.
what apps require root?
Said best
Root means superuser access. That means you have complete control over the entire filesystem.
What that means to the layperson --
You can install apps that require this elevated level of privilege, such as:
AdFree -- block ads!
drocap2 -- take screenshots
setcpu -- manage how fast your CPU goes
Titanium Backup -- the ultimate backup utility
Wifi tether -- turn your phone into a mobile hotspot
etc.
The bootloader may never be decrypted. If all of the "heavy hitters" are now rooted, I don't see why we shouldn't do it. An OTA CANNOT brick your phone because it's rooted.
The question should be, "root or don't root?" I can understand why some people would hold out to see if the bootloader will be decrypted, but if you're going to root you might as well do it now IMO.
Can an OTA break root?
The Froyo OTA update will. Not sure about any minor OTA updates like the one we received the other day.
With that said, you do bring up a point that you can hold out and wait until Froyo to root. That would be the only reason to wait that I see, if you are going to root at all.
Birdman did hint that "something larger than root for the Droid X" is on the horizon, but who knows when that will be. The bootloader is near impossible to crack, but I'm as optimistic as all of you that it will be done. Eventually.
So rooting without the ability to ROM is only temporary! I will wait for now.
Yes, but look at it as practice. :D
Plus you can improve you battery with SetCPU, get rid off all ads with Adfree, and use the mobile wifi hotspot aka mifi for free.
But there's no harm in waiting either.
Froyo is more important than root for me.
Same here. Root makes me this happy: :) Froyo will make me this happy: :D
Now unlocking the bootloader and flashing custom roms would make me... well... :eek::D:D
FroYo is supposed to be here in a couple of weeks. I definitely understand why you would wait.
I just don't see any reason to root unless the boot loader is cracked. The only thing I can see using root for is wireless tethering. What else am I missing by not rooting?
Edit
My droid x is faster and less laggy than my droid running at 1.2 ghz. Setcpu is not all its cracked up to.
You wouldn't be able to use SetCPU to overclock anyways.
What it is very useful for are profiles, specifically forcing the CPU to downclock when the screen is off.
Should make a noticeable difference in battery life.
