Root Rooter needs help resetting...
I have rooted my droidx and removed lots of bloat ware and have a bunch of root only programs and settings changed.
What is the EASIEST way to get back to how the phone came from the factory so I can start over?
EDIT: I have my contacts backed up plus they sync, springpad is synced, facebook is synced. I do not mind to download all the apps over and start over. I just want to start fresh.
EDIT2: I noticed the title is missing the C in Completely
No problem, brother. I'll move you to root section. To the best of my knowledge, if you've rooted, you're gonna need to get those programs back to upgrade to 2.2. I'm assuming you'll need them back to reset.
In any event, this needs to be moved to the sub-forum where folks are more knowledgeable than I am. Good luck, bro! :)
