Root Rooting 605.9
I just want to double check a things before I go ahead and flash the file.
1) flash in hboot
2) power and vol down to get into hboot or do I need to use cmd?
3) I will need to flash the new radios
1)yes
2)either method is fine to get to hboot.
3)yes,you will need to replace the radios after rooting if you want the 930 radios from 2.11.605.9
