Root rooting and ADB ?
adz63
ok i been on unlockr site and found an easy way of putting ROM on . i got to the bit where you have to hold power and home button to get the option to wipe etc but all i got is a triangle with yellow ! and a phone beside it and i cant do anything else ,
please help coz its really starting to do my head in
How To: Load a Custom ROM on Your HTC Hero | TheUnlockr
thats the instructions im following and yes i have just rooted my phone been on market and downloaded an app that needs root to check if i done it properly and works fine
yes slug i did . i tried the method to install custom ROM from the howto install rom sticky on here and tried one from the unlockr site , none have seem to work so i have give up on doing it lol
I am not saying it hasnt but when I was trying to get root (fnar) mine did the self same thing and it turned out I wasnt rooted at all. I even downloaded an app specifically for root, although I never opened it I just assumed that if it had installed I was rooted. What Rom are you on, 1.5 or 2.1 stock? To me it would suggested you aint rooted IMHO
