personally i'm excited for cm9
personally i'm excited for CM9
I'm looking forward to having ICS on my rezound and will probably root to get it. However, when HTC sends it to us with sense 4.0, I'd like to be able to revert back. Will that be possible? Thanks.
if you were to root in order to get ICS (basically flashing a rom) then i doubt that you would even get an update from HTC. Meaning you would have to be stock or close to it in order for you to get the Over the Air update. Once you mod/edit system files on the phone it will not pick up the OTA update. At least that is my experience with past rooted devices.
This is true but all they would need to do is revert back to stock and then they'll receive updates as normal. One of the first things that comes out when s-off is achieved is the stock build. I would suggest that anyone who would possibly want to receive updates make sure they know how to get back to stock.
well i always tell people this.
Rule #1 of Root Club.
1. Make a backup of your stock build as soon as your root.
