Root Rooting and OTA's
Brent372
If I unlock and root my Rezound, will I still get the OTA ICS update?
I have no plans of loading a custom ROM.
Can CWM recovery be used instead of the recovery mentioned in the guide?
sure. you can use any recovery image that you want. id research clockwork however,before commiting to use it... at first it had some issues with the rezound.
