Hello and welcome to Android Forums marscon!
Currently, LQ5 is the latest CF-Root kernel from Chainfire and can be used on any Android 4.0.4 firmware.
Thx i'll try it
The other difficulty I have is, how do I determine my CSC without being able to boot my SGS2? I don't have a recovery section, only access to the Samsung Galaxy SII GT-I9100 splash screen or download mode (ODIN mode) as previously mentioned.
My phone was purchased outright, unlocked so it's not linked to a carrier and the country may not even be based here in Australia. I'm thinking I recall XXLP7 however I could be wrong.
Hi Guys,
I am new the forum. This is a wonderful guide which helped me root my phone with no issues.
I have one question though, after installing the CF-Root kernel that corresponds to my Firmware version, can I flash the latest CF-Root kernel without flashing a new ROM?
In addition, when flashing a ROM, does it come with it's own kernel?
On the invoice I've got when I received my phone, it states Country of Manufacture: Hong Kong, if that helps. I'm trying to flash that unbranded LPG firmware as recommended without luck. In fact, ODIN has been hanging on NAND Write Start for the past 30mins as shown: ODIN-1.jpg download - 2shared
My phone also came out with Gingerbread although I'm not sure which version :S perhaps 2.3.4 but it may have been 2.3.3, I can't remember.
Would the IMEI no provide any assistance?
Also, by trying to flash the stock LPG firmware, does it need to be the original firmware the phone came with? That is, Gingerbread rather than ICS firmware?
Hi everyone,
I've hit a brick wall. About a month ago, I successfully rooted my phone using the instructions provided here on chromefans website.
Anyway, everything was running smoothly until tonight. My battery nearly went flat, I inserted the charger cable and after 20 mins I noticed my phone was turned off. I went to restart my phone, and it got stuck on the opening screen with the exclamation sign. So I removed the battery, restarted the phone, same thing. Tried another fully charged battery, same thing. It wouldn't continue past the start-up screen. So, I'm now at the stage where I'm trying to re-flash my already rooted phone, however ODIN3 v1.83 isn't helping. In fact, I'm getting the following:
<ID:0/052> Added!!
<ID:0/052> Odin v.3 engine (ID:52)..
<ID:0/052> File analysis..
<ID:0/052> SetupConnection..
<ID:0/052> Initialzation..
<ID:0/052> Get PIT for mapping..
<ID:0/052> Firmware update start..
<ID:0/052> zImage
On my SGS2, it displays:
ODIN MODE
Product Name: GT-I9100
Custom Binary Download: Yes (2 Counts)
Current Binary: Custom
The TAR file is the following:
CF-Root-SGS2_XW_XEN_LP7-v5.4-CWM5.tar
Any ideas how to re-flash my SGS2 and get it back to working function?
Thank you
Hey, me again, does the LQ5 Firmware work also for LQB?
Firmware is the whole ROM... so you either install LQ5 or LQB firmware.
Sorry, I meant CF-Root, so I have now the LQB Kernel-Version, does it work when i flash the LQ5 CF-Root on the LQB ?
Dunno! I'm guessing it should as it is still a 4.0.4 firmware. Give it a try and report back.![]()
Sorry about the delay in replying...I just gave up in the end, took it to a phone repair place and after 3 weeks without my SGS2 and $160 later, I have a new motherboard.
Unfortunately now, I'm back to version 2.3.3 on a I9100XWKF3 kernel that doesn't want to update :S Every time I click to check for updates on the phone, I receive "Connection failed" (both wi-fi and 3G). After the last episode with rooting the phone, I'm not too keen on that either.
You don't have to do a full wipe but it is ALWAYS advisable. It will prevent problems popping up further down the line.
1. full wipe
2. start up odin and connect in download mode
3. untick auto-reboot
4. flash lpx
5. if you are not going to do step 7, tick auto-reboot
6. flash siyah (the .tar version)
7. (optional) flash gb bootloader if you want your jig to work
As Siyah auto-roots, this would be job done.
