Lenard The Pig
Agreed, Small steps. Thanks for your help and this thread.
Hi guys, i have successfully rooted my device and is now running thr vk 5.1.2 and siyah 3.3.2. Do i sill need to keep the system power savings thing in settings on?
so it is safe to wipe the info in titanium?System app's will be installed with the Gingerbread firmware.
i'm also a new-bee here.So I'm a newb to rooting and read the whole guide through.
Not had the balls to try it just yet.
Do I need a factory reset of my phone to start the rooting procedure? I think i'm not fully following how i can back up my phone to make sure nothing goes wrong...
Maybe someone can give me a bit more explenation on the back up part?
but i read a lot (atleast that's what i think) about rooting SGSII here and on the XDA forum.
so far i understand, u don't need to factory reset ur phone to root.
the process of ''How To Root'' is given here
http://androidforums.com/galaxy-s2-...t/482994-rooting-galaxy-s2-dummies-guide.html
or u can check this webpage too
AndroidNZ: [At Your Own Risk] How to Root your Samsung Galaxy S II
and for the back up part of your SGSII, check this webpage
AndroidNZ: [At Your Own Risk] How to backup your Rooted 'Droid - NANDROID & Titanium Backup
before doing anything ''READ THOROUGHLY'' and ''READ A LOT'' on how to root.
but be very very careful when doing this becuz it is ur own decision to root and if anything happens u r solely responsible for it.
all the above links are provided by the modders here in many threads.
have a safe ROOTING.....![]()
lSo If I read correct the backups can allow me to reset my phone should anything go wrong while rooting? Or is it purely backup for apps and data?
Is there even a way to restore a root gone wrong? (Is that what they call a bricked phone?)
Is it difficult
That really depends on your level of competency and your ability to read and follow instructions. I would strongly suggest that you read all the links published here to help you understand the process before attempting to root your phone.
[QUOTETitanium backup.
all perfect thanks to this thread, the modders, XDA-forum and AndroidNZ.net.
thank u all.
will be back soon with new quarriessss......![]()
p.s. do i need to flash a kernel right now or maybe later?
and can i flash speedmod kernel into my stock ics 4.0.3 without flashing a custom rom?![]()
can i install a theme like before when unrooted or do i have to flash theme.zip file through recovery?![]()
Ironass, are you Moses in disguise...
i rooted my SGSII last night.
everything is working fine except i cant flash theme.apk.zip file from cwm recovery.
i switched off my phone.
booted into recovery mode (vol up+home+power)
selected install zip file from sd card
(at first i tried to flash theme.zip file from sdcard but in recovery mode i didnt see that file.so i zipped the file from within the phone.this time i saw the file in cwm recovery.)
selected theme.apk.zip file
then i received these following lines
''installation initialize....
installation aborted.....''
i tried to do it again but no luck.
any idea why?
and what should i do now?
can i install the theme.apk file like any other app from the market or should i wipe cache and dalvik cache and then try again to flash the theme.apk.zip?![]()
could you please clarify few things for me here. i'm new to android and still learning. i have sg2 not rooted yet! but it will happen in the nearest future as soon as i know the difference between kernels. from this thread i've learnt that i can root my I9100MULD3 ICS with LP7 kernel, but now what if i want to roll back to GB, do i have to install different kernel?
Now that you are already on stock ICS, you will need to flash a GB ROM/firmware, which will contain its own kernel, to downgrade.
second, some roms that i;ve browsed say that they come with kernel! what does it mean?
Exactly that! The firmware comes with its own kernel to control operations. For an explanation of what a kernel does, see, Android A to Z: What is a kernel?
and, will they(roms) work with LP7 kernel that i will have on my device or i will have to put another kernel again?
ROM's come with their own kernel.
and finally what is the difference between CF-******LP7 kernel and siyah one?
The CF-Root kernel, LP7, is identical to the LP7 kernel that comes with your stock firmware except that it has been engineered to provide you root access. Siyah kernel is one that you can flash after you are rooted and offers battery and performance improvements.
could you please clarify few things for me here. i'm new to android and still learning. i have sg2 not rooted yet! but it will happen in the nearest future as soon as i know the difference between kernels. from this thread i've learnt that i can root my I9100MULD3 ICS with LP7 kernel, but now what if i want to roll back to GB, do i have to install different kernel? second, some roms that i;ve browsed say that they come with kernel! what does it mean? and, will they(roms) work with LP7 kernel that i will have on my device or i will have to put another kernel again? and finally what is the difference between CF-******LP7 kernel and siyah one? i hope i orgonized my questions well. thanks.
