any advice for what i should do now?
Thanks for this guide. I used last night to root my SGS2 without any problems. Is there a 'dummys' guide for reverting back to a stock ROM? I suppose it's just a case of repeating with a stock kernel, rom etc...? Is there a link to download the stock stuff?
I rooted but now I reverted back. I downloaded a unbranded firmware XWLA4 but it started up in German. Can someone just point me to the UK English file I need please. Thanks in advance
I assume you have indeed installed Samsung kies? This installs the USB drivers required for your PC to see your gs2. You say it turned yellow etc. but I just want to know for sure that you have.
also check that you have USB debugging mode ticked in settings, applications, development.
Also insure you don't have kies open before launching Odin.
What I have done:
Observation: Nothing happens. No yellow, no sound from my laptop that a new connection is made, no dismountbutton, silence.
- I have installed Kies on my laptop. Checked if drivers were loaded, yes indeed, since I can connect my I9000 to my laptop.
- I check to make certain:
- Start up Odin
- Connect I9000
- Yellow in Odin with message: ID:0/009>added
- Disconnect. Message: ID:0/009>removed
- I disconnect the I9000 by demounting if from the laptop
- I make certain that KIES is not running on the laptop nor on the I9000
- USB debugging is switched on
- I load CF-Root-SGS2_CE_XEN_KI2-v4.2-CWM4 into ODIN
- I switch off the I9000 and put it in ROOT mode
- Connect via USB to Laptop
My conclusion: The I9000 does not connect via USB to my laptop in ROOT mode.
Any idea what could be the problem and what I could do to connect?
Help is very much welcome
Firstly, I'm not sure what you mean when you say I switch off the I9000 and put it in ROOT mode. I assume you mean DOWNLOAD mode? Perhaps you've buggered up here, and are putting it in UPLOAD mode instead? Need to clarify.
I'm not 100% convinced your following the correct procedure judging by what you have stated. Follow these steps religiously:
1. Download the required cf-root file. This will be in .ZIP format.
2. Open the downloaded ZIP and extract the .TAR file from it.
3. Switch off phone and reboot your phone to download mode. VOL-DOWN+HOME+POWER
4. You should see a warning asking you to press volume up if you want to continue or volume down to cancel. Press volume up.
5. Start Odin .
6. Click on the PDA button and browse to the .TAR extracted in step (2)
7. Connect the USB cable and wait for the ID:COM section to turn yellow
8. Click start to flash.
9. Do not disconnect the cable or turn off the device, it will reboot when it finishes.
).I reread the thread, nice and comprehensive piece of work.
Reason I got into this is that due to an accident my phone needed a new motherboard. I bought it in the netherlands, sim free, and had it repaired in Thailand by Samsung Services, where I live. But now I have only asean languages and english, no Dutch swipe, etc. So I need to replace the kernel.
Following your suggested link if found the XWKK2/XXKI4 kernel with XEN CSC (netherlands) version 2.3.6.
Currently I have: Kernel version: 2.6.35.7-I9100CEKI2-CL586309.
I plan to download the XEN CSC, following your procedures. Will this do the job or do you refer me to another forum?
