ironass
Extreme Android User
Sorry to say but it went again into bootlooping![]()
Did you try wiping the cache partition or Factory Data Resetting?
If I put back the stock samsung firmware can I use other networks than T Mobile ? Since I have pay as you go I could change...
It would seem that your connection problem goes beyond a mere firmware flash and as per your original post, #733, it may go far deeper, perhaps to your /efs/ folder, as it would seem that you have not been able to get a working APN at all. Maybe, you should use the /efs/ repair feature of GSII Repair.
Other than that, I am at a loss to suggest anything else.
