nev_bkd
To root your Galaxy S2, carefully follow the instructions in Rooting Galaxy S2 - Dummies Guide and you will need to add Root Explorer file Manager mentioned in it. I would go for the earliest /efs file backup that you have as the later ones may be compromised.
This post makes more sense to me: http://forum.xda-developers.com/galaxy-s2/help/solved-stuck-flight-mode-efs-issue-t1261948 , although this one http://forum.xda-developers.com/galaxy-s2/help/efs-recovery-t1331701 solved the problem as well
My progress so far:
I successfully rooted the phone and I installed ES file explorer.
I found the efs folder. There, I have nv_data.bin and nv_data.bin.md5 files and their date is shown as 2 oct 015.
I don`t have in the efs folder the .nv_data.bak & nv_data.bak.md5
Ive mentioned in the post before what efs files I have.
Also, I have installed ADB following this guide http://www.howtogeek.com/125769/how-to-install-and-use-abd-the-android-debug-bridge-utility/ and I can see my device when I connect it.
I have 7zip on my PC if I need to explore the .tar
I am not too sure what to do next, I`m scared of ruining it completely. ADB is very unfamiliar to me. Could you please guide me through this process as well ? Thank you
