I'm sorry for asking a question I'm sure has been answered over and over. I've read all the guides and I've gotten to a point where I'm now stuck.
I have the original Evo 4g. I've done the htc dev method succesfully. I created a recovery (I tried the android flasher method but it didn't take since i have S-on) so I went with the ADB method. That worked fine as well. I'm now confused on how to install the custom rom. I downloaded mikg-v3.11
I created a nandroid backup, but I'm now stuck. Do I extract the files from the .zip into the evo folder (simple drag and drop in?), or do I leave the zip file as is, then drag and drop it in? From that point on, where do I go? Do I have to wipe everything? I noticed in the guide it said optional, but everything else I've looked up said that wiping was essential. If I wipe, and something goes wrong, will I still be able to go back to previous factory settings and try again?
Again sorry for the questions, but with 48+ pages of info, I've run out of patience searching. Been working on this for about 2 hours now and I'd love to finally get this thing rooting and running a custom rom.
Thanks!
Thanks!
