Haloman800
Hello. I'm new to the forums, I'm trying to root my Motorola Droid running 2.2 Froyo with OMJ's guide: http://androidforums.com/droid-all-things-root/141116-guide-rooting-2-2-windows-linux.html
I'm at step 10, when I get to the "Battery OK to Program Transfer Mode: USB" screen on my Droid after rebooting while holding UP on the D-pad, my computer says "Found New Hardware: SE Flash Omap3430 MI" And it's asking me to install some driver. It asked me to insert a disc, which I clicked I didn't have, and it asked me to navigate and find it.
I just closed the little window, and went on to step 11, 12, and 13. When I got to the part where I hit "Start", nothing happened, on both the computer and Droid end.
I held down the power button and unplugged the USB from my phone, it turned on like normal, so no brick or any changes whatsoever.
I made sure after I ran RSDLite that I selected the SPRecovery file, but when I hit start, nothing happened.
So, my guess is I need to install the SE Flash Omap3430 MI driver for me to be able to continue on and flash the SPR image onto the phone.
Any idea where I can find this driver, or how I can do this? I'm on the Battery OK OK to program screen again...
Thanks.
Thanks.
