aakenpokid
So I know that if i searched the forums enough i could have found an answer for this, but i wanted a personalized answer.
So I just recently rooted my phone using the instructions at
http://androidforums.com/evo-4g-all...-rooting-gingerbread-2-3-5-dummies-guide.html
I did the HTCdev method, then I went through steps 1, 2, and 3, and flashed the rom recommended in the instructions.
The rom worked great, and the flashing process went fine, but i realized i could no longer receive mms messages, which after researching, i found out that i could only receive mms if i had a sense based rom.
So i searched for one, found DigitalKarma v8 Reincarnation, so i copied the zip to my sd card, and used rom manager to flash it, but it diddn't work. After it flashed the phone was stuck at the white boot screen that says htcEvo4g. So i recovered the past rom and it worked fine. Ive tryed flashing multiple roms now, with the same results.
So if anyone could tell me why none of the roms are working, that would be amazing, or if you have a way to receive mms of the Mikg rom, that would be even better.
THANKS!!!
THANKS!!!
