Root rooting problem: getting errors at step 4b of wildfire-s-finally guide
Hello there. I'm afraid I'm a bit stuck rooting the Wildfire S A510e (Marvel).
I'm following CafeKampuchia's guide: [Guide] How to root the Wildfire S with S-ON (finally!)
My bootloader is showing *** UNLOCKED ***, so now I connect via USB in charge-only mode with USB debugging enabled. I've unrared htcsupertoolv3.rar into a folder - the exe is there next to a folder called root.
I doubleclick SuperTool.exe and the menu appears. I choose (1) for zergRush and this seems to go fine, no errors.
When I choose (3) (Attempt Perm Root) it claims success with a large ROOTED. But in the background I see these errors (copied from a screenshot! they disappear so fast...)
Loading root script......
pushing BusyBox...
changing permissions...
mount: permission denied (are you root?)
/system/xbin/busybox: cannot open for write: Read-only file system
Unable to chmod /system/xbin/busybox: No such file or directory
/system/xbin/busybox: not found
Pushing su...
Unable to chmod /system/bin/su: No such file or directory
rm failed for /system/bin/su, Read-only file system
link failed Read-only file system
pushing SuperUser.apk
If I use TacoRoot instead of zergRush the errors are the same; TacoRoot doesn't seem to actually run btw, there is no screen output at least.
What should I do? Thanks for a good site - Chris
This worked for me:
I worked through the whole of the guide that was failing me, ignoring the errors: [Guide] How to root the Wildfire S with S-ON (finally!)
Then I did step 2 of an older guide: [GUIDE] How to Root the Wildfire S
(both are on this forum)
Maybe I did need to fail at the first guide, and I definitely needed the recovery image the first guide gave me after the errors, else I couldn't have done step 2 of the second guide. Note also that I installed the superuser app from google play at some point.
Hopefully someone can point out what was really going on.
Cheers - C
