Root Round Battery Bar With Percentages!
These batteries are all really cool.. Just wondering if there's any way to get the exact battery percentage on the round batteries like there is on the green option by squintz? Not that it's a huge deal, but once you get under 20%, there's no real way to know how much you have left.. Sorry if this was already asked, but I didn't see it and had to skim quickly since I'm at work haha.. these forums/this phone are gonna get me fired.
Hey guys, I found this one at XDA and it works WONDERFULLY with adrynalyn's Second Wave ROM. xda-developers - View Single Post - [MOD][6th-Aug] Super Circle Battery with % |Version A & B| Desire Froyo/Eclair ROM
Here is the DL for that ROM
xda-developers
Here is what it looks like:
Has anyone tried the round battery bar on adrynalyne's evo port test rom? That's what I'm running and would really like to install this battery bar
That's what I'm using (note the 6 bar signal strength and the round battery icon)
Anyone noticing a discrepancy with the accuracy of the circle display?
Batteryleft is reporting 89% and circle gauge is reporting 80%
the discrepancy persists across a reboot of the device.
Any way I can fix this?
THANKS!!
Yes, I guess I can't read! I was looking back through the thread and saw my answer. Then was on my way back to edit or delete my query.
However, THANKS for the info!
Jim
im sure it can be done but we need to figure out what xml files go to what first... i only know what goes with the battery bar
Has anyone been able to get this to work with FrankenROM? I just flashed the most recent FrankenROM, as of 9/5. Everytime I update using the smooth-sense-1.0-white-battery-text-Incredible-Stock-8-1.zip file an ear symbol goes in the place of the battery icon. I was able to revert back to the original. SkyRaider works great with it as that's what I was using before. But, for some reason FrankenROM has an issue. I am just speculating here but SkyRaider (if I am not mistaken) uses the leak 2.2 Froyo and FrankenROM is using 2.2 Official release.
wont work on franken roms bc it has different frameworks.apks
Smooth sense 1.0 white battery works with Virtuous ROM http://androidforums.com/incredible...e-froyo-v3-21-605-1-w-fixes-enhancements.html I was using FrankenRom as well but went with Virtuous recently and I am very happy with the performance.
If you want to stick with FrankenROM try this MEGAUPLOAD - The leading online storage and file delivery service I am not sure where I found it. XDA or maybe in this thread somewhere. Nandroid first, just in case.
