jabbawest
Do it again and watch the screen on your phone.I get a "$" in the next line.
SuperUser will popup. Hit Allow and continue with the Custom Recovery install procedure.
Ahh, that would have been an important bit of info to haveNot to mention Ive "unrooted" the phone with the gingerbreak option.
haha I told you I was a noobAhh, that would have been an important bit of info to have
You need to be rooted to move forward with installing Recovery and then a ROM.
If you would like to proceed, you need to reroot.
Well that should be an easy fix, download gingerbreak and SU again and then I will get back to you. Luckly I can still sideload
It's quite alright, I was right there with ya and I'm still a n00b, I'm just on a different level.haha I told you I was a noobWell that should be an easy fix, download gingerbreak and SU again and then I will get back to you. Luckly I can still sideload
How's it going?I might have caught a tiny snag... While Ive downloaded Gingerbreak, superuser, and a file explorer... I dont know how I can view them on the phone without the said file explorer already installed. Any ideas?
How's it going?
I know you can't get to The Market so, if you need a file explorer to access the files on your sdcard, here is a copy of esfile explorer.
This will also let you browse files on your LAN.
http://dl.dropbox.com/u/10861860/Android Pulblic/com.estrongs.android.pop.apk
ThinkFree Office (if your phone is still stock) can browse your SD Card and run apps. No need to go to the market.yes Im having some trouble figuring out how to install it to the phone without using the app store. Thats the only way I know of it installing something after its downloaded. Is their an SD card trick im missing?
When I mean stock, I mean the default MetroPCS ROM. Since you haven't done anything yet, you're phone is "stock".How do I tell if its "stock" still?
You should be able to find the program in your app drawer.You don't need to go to The Market.yes Im having some trouble figuring out how to install it to the phone without using the app store. Thats the only way I know of it installing something after its downloaded. Is their an SD card trick im missing?
Do what Darnell said or, if your phone can browse the internet use MetroWeb and just type in the URL to download and then install esfile explorer.
Even easier would be to allow me to email or text the link to you.
Check your PM's if you need to go that route. http://androidforums.com/private.php
when I get a text with a link this is the error message I get. "the application messaging (process com.android.mms) has stoped."he apparently does not have a file explorer on his phone, which means he can not browse to the sd card to get or install the app.Well, I believe you said you could sideload applications. Can you not do that with the esfile explorer app?
I couldn't have explained it any better.
Using ADB to install Applications on your android handset. voxiGee's Blog
Yeh, I know, which is why I suggested installing the file explorer in my dropbox via adb.he apparently does not have a file explorer on his phone, which means he can not browse to the sd card to get or install the app.
install by adb is his only choice I think.
I will keep you posted as I'm sure I will need some pointers in the process! I also wanted you thank you all for your help thus far, and big props to Jabba for going far out of his way to help me.
Congratulations for hanging in there!Any Idea how to stop the scrolling clouds that randomly wash across the screen? Thats my only complaint thus far.
