Help Running out of space
Hi All,
I put a 4gb card into the Avail and moved most of my apps onto it, but am receiving the message that I'm running out of space (only 9mb left!).
The system won't allow me to move more onto the card, even though there is a lot of free space on it. Is there a suggestion on how to move more onto the card so I can download more apps? :confused:
THANKS!
What file manager are you using? ROMtoolbox will force move apps that don't move on their own (through use of the soft key). The free version can still do this. I'm working on an update.zip to move the Dalvik cache to the empty /dev partition
Keep in mind, this all requires root permissions.
