Root Running velocity script V4
Lilg37
i get as far as the masters coding and i get a run script and help message on the screen.. i have the code numbers written down but have no idea how the code should be written in terminal to change anything
can i get some ideas or advice
Which script are you trying to run? For most, if you simply type the script name it will list help.
i figured it out, in the script iwas typing 'master' instead of '(master -r)' got the list up
thanks tho works great on velocity and some options on the punisher rom as well... but it was frowned upon that i did so that particular rom... but in all mishaps great script
