stevevercs
have you run an ruu yet? that,or flashing a rom in recovery would be your first step to get back to a working,booting phone.
test phones did legitimately come s-off,so i wouldnt worry too much about it,as long as youve run an ruu to eliminate any custom rom and recovery,remove root,and get the correct factory software/firmware
the exploits that turn s back to on are only working on old firmware,so it will be a 3 part process,if you want to do it:
1)run ruu for downgrade firmware(1.32.405.6) while s off
2)run aahk to turn s back on(or do it manually wiht gfree)
3)once yours s-on,and the correct cid(if you care about that) youll need to run an ruu to get back to your current firmware. if you have changed your CID back to stock you may need a goldcard to run a branded ruu.
No I haven't tried as of yet purely because i wanted to see whether or not Pep's phone was repaired. As it was, i can now go ahead and try to get my phone to boot, but ideally i need a route that's fast and with minimal input from me, because it seems that if i do anything on the phone, it freezes, and then is random when it decides to boot up again. Which would you say is the fastest way to unroot?
Again, thanks for your help on the matter, and thanks to Pep for being my guinea pig.
