matthewrocz
Has anyone tried this before im interested in knowing if this will work.
The
The
whats the risk level in doing this outta 10? It seems like this kinda thing is pretty high
It took me 5 tries at first to get it on my own phone. Turns out that I wasn't making contact with the other side the first few tries. Once I realized that, I got it on the first try on my friends phone. It works great. Keep in mind that if you do this, if anyone used HTCDev to unlock your bootloader, it will say it's locked but it really isn't after getting S-off
So as long as I wear an anti-static wrist strap to ground myself I should be good? My not so techy friend wants me to root his phone
How'd you do that. My SD card was fine after.
I don't know how I did it. I only did the s-off trick twice and the second time it worked, but when I booted my SD card showed up saying it was blank... so yeah not what I needed, lol.
It took me a few tries because I did it at like 3am, was so tired.
I got scared because it kept "sobering up"; aka failing. and there was no turning back, the phone wouldnt go back into a regular boot without completing the procedure.
One thing is KEY. You HAVE to TAP the wire once on the metal, WAIT, and then hold it to the metal. that was my success. I tried to hold it, tap it a bunch, but what I just said was 100%.
Make sure you DO NOT use an un-insulated wire, and do not touch the connections; you risk damage. I wound up using a paper-clip wrapped in a good amount of electrical tape. I think its better than a wire because a paperclip is pliable and is able to be set in place, you can bend it so you never have to touch anything but the middle where the tape is.
hey guys.
i managed to get s-off but now my volume down key doesnt work
is there any way to fix it? i still get the little click but nothing happens
If you have s-off then there really isn't a need to unlock the bootloader. However if you're anal you don't have to do the whole htcdev thing all over again. You're unlock token is tied to your phone and can be used again. Just fastboot and enter:once your s-off your good to go bro..at least that's what i have gathered from more experienced htc users in tnis community..
but if you really wanna..you can go back through the unlock procedure through htcdev all over again..im pretty sure its completely unnecessary..
but i too re unlocked mine as well..the s-off procedure relocks your bootloader in the process..so not needed but if you want just run back through the process and unlock it again and you will be good
fastboot flash unlocktoken Unlock_code.bin
