Thank you sir. I feel more comfortable now with my research and your help. I will be looking more deeply into s-off as you suggest. If I have more questions, of course, I'll direct them to the sensation threads on this subject.
i was lucky enuff to pick up my sensation on hboot 1.18,and thus able to root it with revolutionary. i have done the wire trick,and used jp bear to s off several rezounds and a gsm evo 3d. :smokingsomb:Sir,
Thank you for your information,
I've followed all the steps, and when running the following:
"fastboot boot recovery-ra-vigor-3.15-gnm.img"
I am getting white screen with HTC logo in green... staying forever
I have a WFS marvel mobile, is there something I can do diffrentlly?
Thanks!
do not confuse this with the fastboot flash command.
fastboot boot is taking an image,and booting it right up on the phone.
fastboot flash is permantly installing an image into the phones filesystem.
I am confused by the 2 statements above.
fastboot flash PERMANENTLY installs the image and fastboot BOOT is booting the image?
I thought flash was a temporary thing and boot was the permanent? I have been trying to flash Neo's infection with this method and gee dangit if I can't get it to go past the ROM's boot screen. Just keeps "loading" and never gets to the set up part.
PS. I see you all over the place here and others and I sure am thankful for folks like you.
the commands are as described. if you wish to permanently install your recovery,use the fastboot flash recovery recoveryname.img command. if you wish to temporarily launch it into memory,you will boot it with fastboot boot recoveryname.img
if you boot your recovery with fastboot boot it will install the kernel normally,just as an s off device would. you shouldnt need to do anything special:
-boot recovery
-full wipe
-flash rom normally
-reboot
the roms now are based on newer firmware,so if your still on GB firmware,then that may be a prollem![]()
Scotty, I am really struggling here. I have to manually flash boot boot.img to get my Rage ROM to load. I followed the steps above again and still need to manually boot on every reboot. I flashed the ROM over the 3.14 unlocked/rooted/Amon RA ROM after flashing Scott's CleanWipe 10X script.
Edit: I am S-On by the way (obviously?)
Edit 2: I think I finally got it. Wasn't flashing the boot.img right. Went to fastboot folder, then "fastboot flash boot boot.img" and it's rebooted twice now. I am a little gun shy on if a reboot ever occurs and I'm no where near my computer. I'll crap em. If I could figure out how to make a PH98IMG file with the boot.img for back up, I'll stop wearing diapers. Until then, it's "oops I crapped my pants" for men.
Is your bootloader unlocked? Youll need to be unlocked,or running a patched/engineering hboot
With the Sensation, I suggest using Revolutionary to s-off your device. It's quite a process from when I had it, a couple years ago, but worked great and allowed for automatic sim unlock too.
hi scotty i used your above method to install cym 9-1 on my htc sensation with s on,i was wondering if the same method would work with a jellybean rom cym 10.0 or do I have to stick to ics roms,thank you
Hey scotty, thanks for all the tutorials. They have been a huge help. I came from the OG Dinc, which was a beast at flashing, haha. Anyway this Rezound is driving me up a wall and I'm beyond frustrated with this thing. Anyway I rooted S-On temporary recovery and was running CM10.1 JB4.2 Rom. A newer version was released so I relocked went to run ruu and I get an error in HBoot that the version is older and update failed. I'm assuming since I was on a JB rom I cannot run an ICS ruu? I am stuck where I'm at. I cannot get anything to boot. I tried reinstalling AmonRa recovery after unlocking again but it says the file is invalid (same recovery I used the first time following your guide). I'm assuming it says its invalid because I was never able to get stock recovery back on. When I choose recovery in fastboot I get the red triangle. Any suggestions.
