scotty85
Extreme Android User
Hey Scotty! My desire S is currently unlocked, but S-ON, HBOOT 2.00.2002. So i fastboot boot Clockworkmodrecovery.img while on bootloader, full wiped then installed a clean copy of this ROM right here: http://forum.xda-developers.com/showthread.php?t=1401563 The problem is that it goes into the recovery i already had (twrp) everytime i reboot the device. So what i did was to restore the version I allready had: fallout v5 ( http://forum.xda-developers.com/showthread.php?t=1679125 ).
I installed Fallout v5 easy, flashing it from permanently installed TWRP while S-ON but no other ROMS work that way. If i flash any other ROMS that way, everytime i reboot the device it goes into recovery. So i tried your method, but no luck.
Then I found another one of your guides: http://androidforums.com/rezound-all-things-root/499172-how-manually-flash-roms.html#post3933400 The problem with this method is that the ROM I'm trying to flash has no boot.img to allow me to flash it from adb, after flashing the ROM. I wanted to flash that older ROM to preserve more battery, but it's too much of a headeache. I wrote this here, seeing that you're the best on this stuff, explaining in detail to every noob. So what shall i do?
sounds like you have used htc dumblock at some point,and thus have twrp recovery installed inthe boot partition.
i would have thot that booting amon would have allowed the boot partition to be overwritten with the roms actual boot image,there are a couple possibilities i can speculate since that first link takes me to a non-existant thread:
1) the booting recovery method simply doesnt work on desire s. its worked on most devices ive personally tested,but there are a couple excpetions(desire hd and flyer that are known to me)
2)that the rom youve chosen is not set up for a recovery flash. i.e.,recovery does not automatically flash the boot partition
sounds like you will have to manually flash the boot image from fastboot,using the basic directions from the other guide. your rom will not boot without a kernel,so its gotta be in there somewhere
just unzip a copy of the rom,and start looking in folders until you find it.
you can then flash the rom,then flash the boot image as described in the installig manually thread.hope that helps
