joeycmb
Here you go. I tried it on jelly bam ROM and it works !!!!!!!!!!so make sure thanks *exProphecy* http://forum.xda-developers.com/showthread.php?t=2199489&nocache=1
Has this been tested on any touchwiz roms?
Before I borked my phone I tried this fix on Jellybam where it worked and once on Midnight where it didn't. I have a theory that this fix only works with JB ROMS, but will have to wait until I get my phone back before I can test this theory further.
You're correct that this only works with JB roms but only if it is a CM10 variant. Touchwiz roms won't work with this because its not based off CM10. However it's weird that you mention Midnight rom not working with this because MMS should already be working on Midnight rom because it is based off stock. To get MMS working on a Touchwiz based rom I use Gosms and manually enter in the APN settings and it works fine.
