S2 boost gb27 ROM help
chevyman1
I was really hoping that someone can help me find a download for the gb27 ROM. Tried to download the one in the post gb27 on the way and I can't open it on my computer. Is there another one I can get to install from a custom recovery? If so which recovery do I need? And help will be appreciated.
do i need to install that with odin? if so where do i get it? i cant seem to get the file open and there were 2 downloads on that link which one do i need? .exe or .gz??? custom recovery so i can make a backup??
Well let us know what u think after u been running the new rom for awhile.
Got it all working mms fixed and its great I reqlly appreciate all your help everyone. Only problem so far is that I cant seem to get the wifi hotspot to work. I installed yellow triangle app. If you know whats up with that that'd be cool. Thanks again everyone
Am I doing something wrong? I used the app you told me to use and went through all the settings like it aaid but my computer wont recognize it anymore and my zte warp can see it but wont connect.
I got it all figured out. Thank you guys for all your help sorry to be a pain. I really like this rom alot better than the stock ics.
I just now figured out one thing.... My 4g keeps trying to find a signal and I don't have 4g in my area. I keep it turned off but it turns itself on and scans for signal. I this is probably draining my battery... Know anything about that?
Check settings in sprint connection manager
menu/settings/more settings/mobile networks/connection optimizer
uncheck box for connection optimizer.
