S4 FM Radio
Xxmen
Member
I notice in the review from GSM Arena that the S4 does not have a FM Radio. Would it be possible to install a backup radio from an HTC or any radio to the S4 like any app?
If it doesn't have the hardware in the phone to pick up FM signals then an app isn't going to do anything.
If you want to listen to MLB (or other sports perhaps?) you will need something that picks up the waves because of internet streaming exclusivity rights. If you aren't into sports though, the internet radio apps are fine.
Exactly. certain stations are not on the internet radio and places with bad coverage will be a problem.:mad:
Yeah, this is the one thing that disappoints me about the S4 (besides same design as last year). But after I see that 1080 Super Amoled screen I'll probably forget about it :D
No FM Radio? WHAT!? You cannot be serious. I'll assume the Exynos version does have one...
FM radio requires a radio transceiver chip with that support. Unlike phone radios where modem support may be processor dependent, I'd be surprised to see this on one variant but not another.
Never say never, just saying.
FM radio is so... old school ;-)
I get what you're saying though..
My guess is they just want you to stream everything now? As in Pandora etc
Which is bad for me because of no longer having unlimited data, I would prefer to have a FM radio. But I will live without it.
Does this mean apps like TuneIn won't work, or is this a different type of service that doesn't rely on an FM signal? What exactly *won't* you be able to do on the S4 without an FM receiver/transmitter?
It just means that you won't be able to listen to FM radio, local broadcasts. You should be able to use any streaming apps just fine since they use the data connection.
It's an important feature for some people, though. Everyone has their own requirements.
