At least the Epic GPS is more useable, until (hopefully) a GalaxyS-wide fix is released by Samsung.
It doesn't seem like the Epic's actual screen size is very much bigger than the Captivate
For anyone who cares:
that blue circle indicating that its not spot on accuracy worries me... When I had the evo, I never had that problem.
According to Engadget, Samsung told them:I guess this makes me feel more confident about the Epic's GPS abilities, but I certainly hope Samsung dials it in better with the fix coming out in Sept. My concern is, will they just find a fix for the Captivate and Vibrant, and leave the Epic as is, calling it good.
Here is his full review
Samsung Epic 4G GPS Test » BriefMobile
Does anyone really drive in New York... Im just saying... lol
aGPS accuracy is 5 to 10m. aGPS is GPS with assistance in initially locating the satellites, but then fix from the satellites.I'll take a 5-10m accuracy over 2500-3000m (aGPS) anyday.![]()
No that would not save battery power. you don't really "connect" to satellites, as the communication is not duplex, but open way, you receive the information from satellites with your GPS radio but do not transmit to satellites. You don't use more battery by receiving the proper number of sats (11 satellites is a typcial number for smartphones on a clear day with no obstructions, and 8 would be average). Four is not very accurate and temporarily dropping one will kill your fix.One of the commenter in that review indicated that "his Epic never had more than four" satellite connections. So I wonder if there is a setting that allows you to connect to more GPS satellites for more accuracy, or less satellites for less power consumption?
"We have tested and validated both Network Assisted (indoor) and Autonomous (outdoor) GPS on the Epic 4G."
Sure sounds like what you see in the video is what you'll get. A fast lock, but still inaccurate. I hope the Captivate fix isn't like what I see in the Epic video. That's just crap accuracy. The blue dot spans 2 streets at times!
