M
milesbennetdyson
Guest
Looks like we might be getting Kit Kat Will Samsung let lower end devices get Android 4.4 KitKat? - AndroidPIT Although I can't see it happening really.
I'm really sorry for the beginner questions but reading through the posts I'm not sure what to do.
The firmware has 2 files... A large md5 file and ss_dl.dll
I have the pit file but what files do I put in CSC and PDA sections?
Thanks again
bro help me update my android phone please my samsung galaxy ace 2 I'm new to this updating things. Im from philippines too.
Thanks for this info, I assume that if I reset the phone i am going to lose all the programmes I have downloaded to it, is there any work around for this?
Either backup or redownload your apps. It's not like your purchases are lost or anything. I've reinstalled apps more times than I can count
There are root apps such as Titanium backup in the Play store
Hi there,
This is my first post so I'm a newbie here!
I followed Smokey's instructions to the letter earlier this week and so far so good, however i have noticed that i cannot activate mobile data. I've tried switching on & off via settings and via widget and also switched phone on and off, but no joy. Can anyone shed any light on this issue and help me resolve it?
Thankyou in advance.
(Samsung Galaxy Ace 2, Jellybean. Network provider AIS 3G Thailand)
Hello!
I have recently backed up and reflashed stock android 4.3 on my Galaxy Nexus as a way to clear out unwanted apps and improve what had become a very laggy phone. It appears to have worked well, however my daughter would like me to do something similar on her Galaxy Ace 2 in order to try to revive it.
When I flashed my phone I used the excellent Wugs Nexus Root Toolkit which automates all the steps needed to backup, flash and restore.
Please could someone post some instructions for how to do this manually for the Galaxy Ace 2 (unless you know of a toolkit for doing this automatically). My particular concerns are:
I have followed a number of threads on these forums but can't seem to find clear instructions for this.
- How to backup apps and data securely?
- How to flash the stock Jellybean ROM?
- How to restore apps and data?
As an alternative, my daughter would like to try and return to Gingerbread which she feels was more responsive but I have only found references to a Russian GB ROM and I'm a bit nervous about trying that.
Can anyone suggest a ROM I might try that would respond better than the stock Jellybean? Maybe a CM ROM?
Is there a simple route back to the stock ROM if the customised ROM has problems?
Sorry for having so many questions!
Thanks in advance for any suggestion,
Julian
Beware, if your phone is from (Hong Kong)? Than you have a problem.
Phones from Hong Kong are different and the radios operate differently from the rest of the world phones...
I have the hong kong phone. What should I do to update?
Good luck!Here is a question to ponder on. Is it to do with the touchscreen - i.e. it is something physical (hardware) on certain phones rather that software?? Sometimes the phone just doesn't seem to react - so I try the action again, nothing then try again and still nothing and the other times it responds immediately.
Ur better off just flashing the rom straight off with gapps and recovery if needed thats what i did and only thing that went wrong was no data signal couldnt call or get 3g. I could send and recieve sms from my fne tho so confused me a lil bit but after flashing bk to stock and then reinstall cm 10.2 I went and gotvthe cm 11 wich has been ok .. oh the problem with my fne was a borked radio but if your imei has gone id say its a bit worse than that...Hi all,
I'm new too and just wanted to ask a quick question. I can't get the MB2/MB4 links to work so I have just downloaded BTU-I8160XXMK2.
Can I use pit file and this firmware to upgrade straight from GB?
Just didn't want to get stuck into page 1 guide before asking
My setup is
Android Ver 2.3.6 Gingerbread
Baseband Ver = I8160DXMA1
THL firmware
Thanks
Or samsung firmware websiiteDownload Kies and check for updates from Samsung.
Or search for Hong Kong specific firmware only.
: confused:Or look on xda for custom roms and just to be safe, make sure to verify that the rom is compatible with Hong Kong devices.
Good luck!
