Help samsung galaxy ace 2 usb otg
Welcome to AF, wsj69! :)
I moved your post here to see if these folk could help you out with this.
I hope you get it figured out.
Thank you, again, for joining! :D
Google search is your friend.
Just type in the search box "Samsung Galaxy Ace 2 usb otg" and you should find your answer.
I tryes that so far i know its possible but i could not find out how
Yes, from a simple Google search I was also able to discover it is possible. However, possible does not mean easy or possible for the non power-user.
While possible it seems it is not supported out-of-the-box and would take a knowledgeable power user to find a way to make it work. My best suggestion to you is to assume that it doesn't work if you're using it as a deciding factor for purchasing a device. Apparently the Sony Xperia P supports OTG out-of-the-box but I don't know much about that.
