Help Samsung galaxy S2 - problem?
j3ff3
Hello!
Long time lurker, but i thought I'd combine an introduction with a question about my new phone, the S2.
Has anyone else noticed that the volume rocker on the side of the phone is quite loose? not vertically, but backwards and forwards. Went into town today and tested two more phones that had the same issue. It just makes an otherwise perfect phone feel a little tacky.....
Jeff
Welcome to AF.com!! I'll move this post to the Galaxy S2 sub-forum so other owners can chime in.
ahhh, thank you very much - i did look for a phone subforum, but clearly not hard enough :D
**edit - i see it. thought it was an advert or the usual junk you get at the bottom of the forum with all that writing. my mistake!
Hello!
Jeff
No sideways movement whatsoever on mine!
cheers for the reply ironass (:D)
not to doubt your use of the word 'whatsoever', but are you 100% sure there is no movement? it just seems odd that there has been on the 3 models i've tried, however slight.
i'm within my 7 days cooling off period, and i know its a little picky of me to ask for a replacement, but if i can get one that has a better build quality i wouldn't mind it! its just i hold the phone on the button with my left hand, and even a slight movement annoys me :p
