I recently had an issue with my S4 lock screen and when I googled around for advice on a fix I couldn't find a definitive answer other than try this that or the other and see what happens. Now I've found the issue I thought I would come on and post the fix that worked for me and see if that helps anyone else.
The issue I had was that when I locked the screen and put the phone away I then had an issue trying to wake it back up again when I wanted to use it. The back and menu keys would light up but nothing else would happen. Sometimes the screen would come on but was unresponsive when I tried to unlock it.
Some people said it was due to KitKat but I had this issue before that, the update just made it a lot worse. I tried restoring the phone to factory settings which didn't help either.
I found a temporary fix that worked which was to download a new lock screen but I didn't like it so I gave in and sent it off to Samsung for repair. In the mean time I needed a phone so my fiance let me use his phone which is the same phone except it's white. He's never had this lock screen issue yet once I started using it the issue popped up. So we figured out we needn't have sent the other phone off to be looked at.
The only difference we could think of was the apps we had installed so I started the process of removing apps one at a time to see if there was any difference... I got lucky nearly right away and removed an app and since then have had no issues at all.
The app I removed was "Advanced Task Killer" ... i've never had issues with this app in the past so I am assuming it is something to do with one of the apps recent updates or something. I have no idea why it does it but I know that it was the cause of my problems.
If you have this issue and this app installed try uninstalling the app and see if that fixes the issue. If it doesn't then go through all the apps one at a time until you find the issue before sending it in to be repaired. I know it wont be a fix for everyone but it could be for a few people.
Whenever I look for help with an issue on anything (not just phones) I find lots of people asking the same question but no one seems to come back with an answer so I thought seeing as I have an answer that may save some people time, money and having to send in their precious phones I would share what I know and what helped me.
I hope this solves the issue for some of you. Maybe if anyone finds that it is a different app or completely different reason for the issue they could post it here so people can find answers easily??
