I used to have an auto-correct / spell checker on my samsung S2, but since the latest android update it no longer works. I have checked various places online and most say it should still be there, but I cannot locate anything under Setting>Language and Input.
The options on the samsung website show the following:
Auto correction: When you touch the spacebar or enter punctuation, mistyped words will be auto-corrected.
Show correction suggestions: Select when you want your device to show you suggested words during text entry.
However when I misspell a word it leaves it wrong even though the correct spelling shows up in blue on the predictive text bar. It will only change if I press the blue word on the bar, this is fiddly when typing a message quickly and also means I am unable to add my own words to the 'dictionary'.
Any ideas?
Any ideas?
