Root Samsung Transform ultra All in one Root Mod Guide.
NGD1
Android Expert
:D- OVERVIEW -:D
This Guide is designed to Teach the up and coming developers and Modders that have a Samsung Transform Ultra how to modify and customize their devices.
It is also here to serve as a one stop shop for experienced Users who are looking for the correct files to edit or root their device.
Sections said:
Section 1:
Tools files and overview.
Section 2:
ClockworkMod Recovery and Root
Section3:
Finding and Installing Custom Roms
Section 4:
Re-Installing the Stock Rom and Recovery
Section 5:
CREDIT!
;)- TOOLS AND FILES -;)
Universal Tools used Throughout the entire Guide:
-Odin Tool
-Samsung Drivers
ClockWorkMod Files:
-CWM_TU.tar outdated--please use CWM from link below:
-TransformUltra.Ops
-tu_root_.zip
Current Custom Roms For the Transform Ultra:
-MegaTron Rom
-CTMod Rom
-Explosion Rom
-iDEV Rom
Stock Rom's, Recoveries and Kernels For both Boost And Sprint Transform Ultra's:
Roms:
-Stock Boost Rom
-Stock Sprint Rom
Recoveries:
-Stock Boost Recovery
-Stock Sprint Recovery
Kernels:
-Stock Boost Kernel
-Stock Sprint Kernel
Un-Root Files:
-TU_Boost_Unroot.zip
-TU_Sprint_Unroot.zip
Transform Ultra Complete Rooting and Modification Kit With Instructions:
-TU_Root_Mod_Kit.zip
Disclaimer said:
This guide is built to assist with developers and new users, in no way am i or any of the mentioned developers responsible for your device, follow the directs and nothing should go wrong
the information on this guide is set up to be corrected and edited frequintly so no links or files should be damaged, if any are please bring it to our attention and it will be resolved.
- ClockworkMod Recovery and Root -
Description said:
This section of the guide will walk you through Installing a Custom Recovery and Rooting your device.
:eek:Tools and Files you will need: (TU_Root.zip), (CWM_TU.tar), (Odin.exe):eek:
1. Copy the file named (Tu_root) onto your SD card before we began.
2. Install samsung drivers if you don't have them already: (SAMSUNG_USB_Driver_for_Mobile_Phones_x86).
3. Open the Odin.exe in the folder : (Odin_Multi_Downloader_v4.42), [Run as administrator].
4. Hit the "OPS" button and select the TransformUltra.ops file from the folder (TransformUltra.ops).
5. Select the "One Package" Button and select the CWM_TU.tar from the folder (CWM_TU.tar).
6. Now put your phone into download mode (Vol down + camera + power).
7. Plugin your phone and the yellow COM should light up in the upper left.
(make sure your phones back is removed for quick access to the batter for the following steps!!)
8. As soon as you hit start, remove the battery from the phone.
9. Wait until Odin finishes and shuts off the phone. Pull the battery and take it off the usb so it doesn't reboot.
10. Put the battery back in the phone and boot strait into recovery (by Pressing and holding down the:
(Volume Down + power Button) at the same time.
11. Once in Recovery select "install zip from sdcard".
(note use the volume keys to go up and down the list and the power button to slect the option!)
12. Select "choose zip from sdcard"
13. Locate(tu_root.zip) from where you saved it on youe sd card.
14. Select "yes"
15. Once complete Navigate to where it says "Reboot Device" and Select it.
16.
Once booted Install Something from The Google Play store (Install Superuser and update su and busybox).
(if you wish to Un-Root your Device Follow steps 12-16 but instead of installing (tu_root.zip), Install (tu_boost_unroot) or (tu_Sprint_unroot) depending on your carrier.
Congratz!!! your Transform Ultra is Now Rooted and can Install Custom Roms!
;) - FINDING AND INSTALLING CUSTOM ROMS - ;)
Description said:
This Section Will teach you how to Install Custom Roms onto your Device.
1. Put the Rom you want onto your SD CARD!
Here's a list of Roms for the Transform Ultra
-MegaTron Rom
-CTMod Rom
-Explosion Rom
-iDEV Rom
2. Boot into Recovery.
3. Clear Dalvik Cache(in advanced).
4. Clear Cache.
5. select "install zip from sdcard".
6. Select "zip from sdcard".
7. Locate the Rom you wish to install onto your Transform ultra and Select it.
8. Let the Recovery Do its Thing and Reboot your device
Your Done! enjoy your new Rom!:rock:
(note: ONLY INSTALL ROMS THAT YOU KNOW IS BUILT FOR YOUR DEVICE!)
:( - Re-Installing the Stock Rom and Recovery - :(
Description said:
This section of the guide will walk you through Re-Installing the Stock Recovery and Rom onto your device for both BOOST and Sprint.
1. Install(if you havn't) Odin and start it up (in administrator mode).
2. put your device into Download Mode (volume down + camera + power buttons) at the same time.
3. plug your Usb cord from your computer Into your phone you will see a yellow box with (COM) light up, thats your phone.
4. Click OPS and select the file (TransformUltra.ops).
5. For either version (Boost / Sprint ) Find the Option called (One Package) you will be using that from now on.
6. Using "One Package" select The corasponding Stock Rom you Downloaded. (and click start).
7. Once Odin is finished, repeat the previous Steps for The (Tu_(carrier name)_stock_recovery.Tar
your phone is now Back to Stock.
:beerglass:CREDIT AND SUPPORT!:beerglass:​
Description said:
This section is to present everyone who made this thread AND these roms and tools possible! so say thank you!
1. Chevanlol360
2. Loota
3. Bloodawn
4. mavrikmeercat
5. Slayer72
6. jdogrambo
7. ibrickphones
8. bads3ctor
9. NGD1
GO SAY THANK YOU FOR THIS AWESOMENESS!!!!!!
very nice job bro...well done only suggestions is maybe add lootas video on cwm..but still good work...STICKY THREAD mods :)
This was very well written! A Perfect how to & where can I find it Guide! I luv it! Maybe the other threads won't get so cluttered up with repeated questions anymore! The answers are all Here on Your Ultra-Pedia Guide! Lol Great Job Bro!!
NGD1 i added a link for this to my Newbie guide/thread.. hope thats cool
its cool dmc
and thank you vmed =]
like mentioned before all input is welcome, this guide will be formatted to work on XDA and a few others soon and i will be using its base to create a few more ALL-IN-Ones over the next few weeks!
This should be stickied.
For now due to there being several guides mucking up the sticky area, its being featured WITHIN apparently two larger guides now
which is fine, im not looking to be famous, just wanting to help =]
Nice work, NGD1. :) Just a few quick helpful hints:
1. At the beginning of the guide, installing the latest drivers should probably be first, since the computer will refuse to recognize the phone without the proper drivers (or at least I've found that to be the case on Windows XP computers).
2. At the end of the guide where you mention un-root, you say to follow steps 16-19, but 16 is the last step :p
3. I know others have asked Bloodawn (CTMod's creator) if they could mirror his ROM or link to it, and he has asked that they link to the thread instead, because he keeps track of the number of times it's downloaded.
4. Spelling, grammar, blah blah blah.... :D :p Just a personal pet-peeve of mine, not really an important point.
But again, good job :)
if you look in the Rooting and Recovery Section The Drivers is the 2nd / 1st actual step.
16 / 19 has been corrected to 12-16
all the rom links Are linked to the threads, the only direct downloads are in the tool section (not roms)
thank you =]
I havent tried this yet but wanted to say thanks for the info and tons of help. There are a few links you have posted that goe's to minus, they arent available anymore like: tu.root.zip and rom for boost. Are those important or can I do without? I will post on my experience after trying this for the first time ever. I want to get into the tech criteria, I'm planning to get into a school for pc programing and down the road app developer. So I have to say all of you guys inspire me to do so with such knowledge and determination is put in to create such apps!
Thank you for letting me know, i will have the Items Replaced Today and i will message you when they are fixed.
EDIT:
I checked all of the links and they are functioning correctly, what may i ask is the error you are receiving?.
