scudder
Android Expert
So I have some sort of battery status APK file (widget) that I installed on my EVO within a couple days after I got it back in June. I wanted to share or otherwise provide a friend with the APK to install on his phone, however, the app is NO LONGER available....
Soooo, what I'd thinking I MIGHT be able to do is the following:
I have the APK backed up using Titanium Backup Pro. I can see the file when I mount my SD Card in sdcard/TitaniumBackup (my backup directory for Ti Pro). There are 3 files....one with extension .properies (probably settings) and two other .gz archive files...one .tar.gz and the other .apk.gz.
Can I save the .apk.gz file and extract the APK from the .apk.gz file on my desktop so that I have THE APK FILE which I can THEN sent to my friend to install on his phone? Or is this Titanium Backup .apk.gz file a bit more than just a gz compressed apk file that I can use as simply as I hope??
THANKS!!
THANKS!!
Problem is that the "App Sharing" option merely sends a link to the Market...and the app isn't there anymore. It doesn't share or attach the ACTUAL APP, just a link for downloading...
. You're fine, I just want to make sure you don't take your new found power and do something you probably shouldn't
. I think you already understand, that though. As for potential problems doing this, you might run into issues with restoring app + data (if you'd done it through titanium, but that would depend completely on the app. Some apps just don't like it. Just installing the apk that way should always work fine.
