If they are market apps then you will need to root your phone.
Once rooted, install an application called Root Explorer.
Then open this app and navigate to: data>app
In this folder are all the market apps you downloaded. You can copy all of them to your computer
The other way is to go into Settings and then Privacy. Check Automatic restore. This way only backs up your phone does not actually save the installation files to your computer.
