new optimus
Android Expert
Ok as the title says Are there sbc kernels for gingerbread sense roms.
No, there aren't. Sorry!Ok as the title says Are there sbc kernels for gingerbread sense roms.
OK thanks, I am happy with decks aosp gingerbread and the sbc I have but a guy I know may be more comfortable with sense, and the ability to use the ## menu and the battery life and usability on sbc is awesome.
Thank you for the suggestions but I dont think he would want to go back to froyo, while it was great at the time the improvements in gingerbread are tough to resist.well he can try a froyo rom and then use netarchy toastmod's sbc kernels:
[Kernel]netarchy-toastmod, Stable: 4.3.1 Beta: 4.3.4 (17-Mar-2011) Now With HDMwIn - xda-developers
i would try the 4.3.4 cfs sbc more havs kernel. that worked well for me. but you know kernels are always YRMV.
also if you go froyo, i would recommend that you try mikfroyo 4.61 and koni's elite series iii. those were two of my favorite froyo roms.
thanks I will pass it on, maybe if I get ahold of the phone and put it on for him he wont.mikfroyo and koni's elite are awesome roms. i doubt that he will know the difference really.![]()
I would off what I am doing.
I use Boot Manager
I have MikG 3.0 as the main ROM on my phone, then I used Boot Manager to install a second ROM on it and I use Warm 2.2 RLS5 in slot 1( if you use BM it will make sense) Then I installed the Netarchy kernel listed above in that ROM, so now I can run my daily ROM, MikG all day, then I switch to Warm at night to charge with SBC. Most times I can go 2 days on a 3500 batt on Mikg and it takes about 6 hours to charge with Warm.
BM is a great program now with all the updates. It is pretty much Bullet proof. There are posts on here by me and a few others on how to avoid any troubles. READ THEM FIRST!!
