Root SBF Failing
dhoffman1421
Trying to get back to .340 from leaked GB so I can go to new GB leak .588
Using the VRZ_MB810_2.3.34_1FF_01.sbf and RSD Lite 4.8
It appears to finish complete but sticks at red droid eye when it autromatically reboots and they prompts do it manually. 3 times, I have tried with same exact results.
Any ideas? Any help appreciated...
You need to go into stock recovery and clear cache/data and reboot and it will stop boot looping. To get into stock recovery hold the home key and the power button together until you see an ! Inside a triangle with a droid next to it. Then release home and power and hit the search key (since you had the first leak you may have to hit both volume buttons at the same time instead of the search key) to get into the menu,scroll up/down with the volume keys to get to data/cache, when its done reboot.
Thx guys, only the second time I needed or tried to SBF and the first t ime I didn't run into this so I was freaking a little.
